"JK D44's are a different story, i think they make those out of rubber, scary easy to crush those."... we could all kinds of fun making comments on this! lol
Yeah, shim stack so I could get in there and not mess the preload up. I"m guessing 150ftlbs on the pinion nut. I'll do some more looking but having trouble finding a torque amt for it... ??
Anyway, fuel line that for 25 years exited the frame on the bottom of the rail directly above the axle of all places has been moved, frame has been hacked and repaired with a pc welded on the outside to cover the hole instead of flush. Main reason for this was so if I ever need to get into the frame again and replace the fuel line I can cut this pc off with a cutoff wheel then have better access to remove/replace the line. I have fuel hose slid over most of the fuel line (brake line) to keep any potential contact spots from wearing. Been running it like this for close to 20 yrs now.
Brake part inventory and layout tonight... drivelines should be here by Friday for mockup and angle testing. I'm thinking I will probably need a limiter for the front ...dang it. Maybe one inch...will see.
Friend is picking up my converter within an hour and he will make a 1/2" long button, TIG it on the TC and turn it true. I call Rev?? about converters this am- no luck but they did say do NOT run the TC unsupported and that adding a 1/2" was probably my best option.
