On the left side of the Winters gate btw R & N there is normally a gate.
By cutting it out I can now with only 2 motions move my shifter from Park to Drive. Without cutting that gate out it would take 6 separate motions of the shifter to get to Drive. Much nicer for the # of times a day I drive it. Perfect
I have to cover the gear selection "spots" in the Winters gates (2 & 1) below the "3" on the shifter gate for the 6r80. I don't need any gates below "3". I have an alum cover in the pic but haven't attached it to this new gate yet.
Now the really neat part is I can drop the shifter down the left side of the gate into "3" (in only 2 motions) which is Drive and then kick it over to the right so it can't accidently shift into any other gear AND because of my wiring on the Quick 6 I can now access "manual" mode in my trans by just leaving the shifter in Drive (OE shifters you have to manually move the shifter to the "2" position). Then I flip an on/off switch to on and then running the auto like a manual by just clicking a momentary double pole rocker switch!
It's exactly, I mean exactly what I wanted. Total full control of the trans in any and every gear manually and by flipping a simple on/off switch I can drive it in full automatice mode with a choice of 4 very different tunes... from "ice cream tune" meaning nice easy soft shifts (USSHIFT calls this Medium-Hard shift) to full max shift capacity shifting for sand dune climbing and nasty deep concrete slush type snow. Way cool.
For those of you still reading
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, I made a little hinged plate for blocking out "Park". What this does is allow me to be wheeling and if I'm in a nasty spot where I might get a little light in the front end or worry about it coming over the top I would have already flipped this hinged plate over and it will completely block out the shifters ability to move into park when and if I need to ram it into reverse quickly. Super simple, could be cleaner but it was temporary also to see if I was keeping the Winters and it works great.
I finished converting the Winters back to gate style shifting and installed (temporary again) a momentary rocker switch and now I feel I have the trans I wanted since I installed the 4r70 back in 2011. Took it for a quick ride tonight... chirps often into 2nd when over 3K rpm.
I have 2 transmissions in one: full auto with 4 different tunes and full manual without any overides from the tranny.
So this winter I will build a new console to house what I think I want permanently mounted - - a Winters shifter with gates modified for safety and a simple momentary rocker switch for total manual control of the 6r80... dang, I'm so excited... it shifts so smooth manually, exactly when I want... best of both.
I think I can officially declare, even w/o wheeling it any where yet that this is the BEST all 'round trans I've ever had in my Bronco... and it's the SEVENTH one I've had now!
lol
Hope all this helps someone doing their own swap!
