- Joined
- Jun 4, 2002
- Messages
- 35,678
6 holes, 18k per mile. Right in the middle of that speedo's input range. shouldwork perfect.
sounds pretty sweet - got any pics? how is your rear driveshaft angle? Do you know how much longer the 4 speed is compared to the 2 speed? I dont think i'd go 4 speed but I'm just curious.
thats awesome... could you safely down shift while the torque converter is locked? I have a bit of a guilty pleasure I will miss when going to an automatic - I like to pop the clutch when down shifting to make the rear tires chirp. The sudden rumble from the glass packs and the tires screeching at the same time is music to my ears.
so... i'm thinking I should be able to use one of these Nordskogg digital speedometers spliced into a wire on my OSS.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=NRD%2DM9222%2DAS&N=700+4294925228+4294815743+4294895640+115&autoview=sku
That should work right? it has a calibration setting. Obviously it will be incorrect in low range but that doesn't matter.
here's a pic that shows the changes in 04
You can see the gears are extended to replace the 6 holes
Dan, you requested pics 10 days ago. The pics should work now.
picked up my throttle position sensor this morning. It's not quite what I expected even though the parts store said it's interchangeable with the TH31 recommended by the tech section on becontrols.com. The problem with this TPS is it has no lever. I had them find me a TPS from a 95 ford F-series and it was basically the same story.
This TPS was $40 at the local parts store. Not too bad relative to some of the other ones I've been quoted.
I guess I'm going to have to fab something up. I'm probably going to take a piece of round stock and cut some grooves into it and weld on a lever. Then I'll have to figure out a way to keep the lever and round piece from slipping out. I suppose I could just JB-weld it.
I also picked up some new motor mounts. After taking my headers off I could see that my existing motor mounts are in terrible shape. Now I need to go buy an engine hoist from harbor freight. It just keeps adding up.
That looks exactly like the factory TPS on my Explorer throttle body. My throttle body has a flat blade on the end of the shaft that engages the plastic fins inside the TPS. Is your throttle body different?
As for your Atlas hanging too low, mine's clocked (I think) one position up from lowest. The t-case clears the driver's side radius arm mount by, oh, maybe 1/4 inch, and it hangs down below the frame rail. I hated it being that low, but after 4 years of wheeling it that way it's been a non-issue so I never did anything about it. I sat the whole Bronco down on the transfer case a couple of times on the Rubicon. It barely scraped the case. On less difficult trails other stuff hits long before the transfer case. Oh well. Just one data point...
i'm still carbureted so this is a bit of a retrofit. What year explorer do you have? Maybe I can hit the junkyard and find a piece that slips into that TPS so I dont have to fabricate something.
