Mike, please look at my build, I'm ready to cut.
Serguei has examined the cover and knows what I suspected- The covers aren't Sunbrella. If they were, he'd have stopped making them long before he did because its $21/yd times 6 yds or $126 just for the material. He's looking at making the first couple in Sunbrella to test because he has the material on hand but is looking at a better (more waterproof) material for future covers;
VINYL-TEX 18 oz. Vinyl Coated Fabric
18 oz. 61" Imported Vinyl Coated Fabric
PVC Coated Polyester fabric.
UV Resistant and Mildew Resistant.
Applications Include:
Trucks and Equipment Canopies Dry Bags
Curtains Tarps Shelters
VINYL-TEX Technical Data
Base fabric - 5.2 OZ. SY 100% polyester
Coating - PVC
Width - 61 inches
Total Weight -18 oz. per square yard
Tear strength - 81/83 lbs.
Tensile strength - 444/441 lbs.
Low temperature, -40 degrees F.
Flame resistance - Unknown
Shade Factor - 100%
This shouldn't sag as much but will be harder to fold up. It would definitely be better on the trailer going down the road. He says the reason the sides were short was to get under a certain ammount of material keeping the cost down. Have to see samples before proceeding. Its available in 9-10 colors. NO you can't have pink Tasker....
dug this up out of old threads:
"It is a marine fabric with one of it's specific uses being boat covers that is highly water repellant. It is not water proof like vinyl would be though. I.E. If water puddles up in the center it could potentially seep through if left there long enough. (For long term storage I would run a 2x2 or so board across inside anywhere that could build up water) If he is familiar with Sunbrella fabric (Which is what the canback and Galens doors were using) then this fabric is a tighter weave that seems to be more water repellant than it is. Keep in mind that you do not want an absolutely waterproof material because it doesn't breathe at all and can cuase other problems. I have tested it using a garden hose both with a pressure nozzle against the sides and by allowing water to run onto the top to puddle up. (As much as possible which was in only one small area about 12" in diameter) In both cases I couldn't find any evidence of leaking. (I even took my hand and rubbed the area under the puddle such as that which would cause a tent to leak) As far as holding up I ran it down the freeway at 70 yesterday with the front edge stretched over my mirror mounts (To see if it was durable enough to hold up even stretched over the edges of the mounts). It was on the freeway for about an hour and held up just fine."
and
Here are some features:
- Sea Mark/Sunbrella outer skin. Sunbrella has an excellent reputation in the marine industry of providing a marine canvas that stands up to the elements. This is available in about 10 different colors using Sea Mark and about 40 additional colors using standard Sunbrella. (Sea Mark is a Sunbrella with a vinyl backing added to it)
just and FYI
sooooo pick up my trail tub next week?
HAHAHAHA, but I'll need some of Mikes custom fiberglass to cover the sharp edges!!i have wicked shaaarp butter knife.....
Ok Mike, here is a pic with your half cab on, I need to get this thing cut!
The designmeister is back to 8 fingers and TWO thumbs. Just left the Doc and he says I'll be back to full strength with a little flexing and strength exercising.
I personally know of an upholsterer that made about a dozen tops to be sold excusively through BCBs. They are great tops made of Sunberela. I don't think they sold very well. Priced around the high $300s. How does that compare to your product? Good luck in your indevore.
;D
As for Ben, his cover will take 50 yds because he can't leave well enough alone.... ;D;D
