You are right on Steve! I am a little bit concerned now that I'm not the only guy that's had this issue... Of course, PA denies there is an issue. Exactly what they tell ALL the people that try to explain that the converter snout doesn't fit in the end of the crank either- total denial. Playing dumb.
You know I'm not a polish guy either, I'm a driver. I will keep checking my flexplate every time I am under it checking for loose bolts, ujoints etc .
I know a Bronco outfit looking to make an adapter and I hope they jump into the ring and provide a kit. It's a heck of a tranny.
There is another company now (course not 2 yrs ago when I could have used it!) making adapters for a 6r80 to fit SBF and they are stout looking. My concerns about their new approach are twofold with theirs but it isn't a weakpoint from a breakdown standpoint but there are drawbacks...
1- they use a single 2" thick piece of alum for a spacer between bellhousing on the trans to the back of the block. This does several things which make it stronger than the PA kit.
1- no more TC spacer studs which I believe caused my issue
2- no more "huge" hole in the side of the tranny bellhousing so your stock starter fits & creating a potential weak spot in the bellhousing - - although even on forums I haven't heard of it causing an issue
3- no more hassle with the snout on the converter not fitting into the back of the crank and the PA reps saying the TC doesn't need any support
The issues I listed above are potential breakdown spots I feel but there are other drawbacks too.
I will find their site and post up.
https://transmissionadapters.com/blogs/blog/sbf-to-6r80-kit-is-in-the-works
My concern with this this new kit is it uses what looks like a rock solid alum billet spacer for the converter to bolt to but it weighs about 13 lbs. That is a LOT of extra weight spinning around. I know it would affect acceleration & performance but I don't know of any other detriments from a weight standpoint. Obviously it is neutral balanced and since you have more normal contact points btw the TC and flexplate with this kit you won't have cracking/shear issues like the small spacer studs I have from the PA adapter.
It uses a non-stock starter. Not sure what that means other than it's not a SBF starter. I will try to find out if it is OE for some other vehicle that could be replaced when on the road.
A problem for us short WB Bronco owners is it adds 2 MORE inches to the drivetrain and makes rear driveline angles worse.
