6:30 am till 11pm shift... buddy came over and we attacked the "too long, too short, need to move, gotta add this, don't need this" wiring rat's nest that happens when you remove the core support!!
Lot's done yesterday... finally got 99% of the air out of the pwr strg... after I had spent at least 4 solid hours following PSC and Hydratech's step by step bleeding instructions- - - I cracked the fittings at the ram as Tim cranked the wheel and the air bleeding out of the ram could be heard across the shop.
There's no way for that air to get "shoved" out of the ram because it is dead-ended against the piston.
Anyway, won't waste so much time cranking the wheel 200 X before cracking those fittings!
This reservoir extension really helps allow you to pour enough fluid in when the system has so much air it compresses it alot then burps it out when you shut the engine off. This allows you to "over-fill" it, then as you bleed the air out the level lowers and you don't have a mess on the floor.
I usually syphon off to reach the level needed when done bleeding.
